Results 1 to 7 of 7
Thread: X-flow water pump connector
    Aug 2018
    manchester
    36
    Rolleyes X-flow water pump connector
    I need some help!
    I've got a water pump on my crossflow but there is no union in the top to marry the water pump to the heater pipe. I ordered what I thought would fit from Burton as it was the only thing remotely similar looking on the site (link below) but it is too big.
    http://www.burtonpower.com/water-uni...ght-fp477.html
    Has anyone got a clue of the size of this and where to buy one?
    Thanks!
    Click image for larger version Name:	Untitled.png Views:	61 Size:	148.6 KB ID:	82982
    4,889
    Re: X-flow water pump connector
    3/8"NPT is the size for the XFlow waterpump.
    I use the Burton FP379 (angled outlet).
    http://www.burtonpower.com/water-uni...bow-fp479.html
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Worth winding a bit of Ptfe tape round it first.
    Could save you some agro later on
    The pump connector is suppose to already be a 3/8 npt union that gaz has been supplied from BLurton and it won't fit.
    3,239
    So someone has to measure the hole, measure the thread pitch and work out what is actually needed...........or buy a new water pump that hasn't been molested!
    4,889
    Can you post a photo of the union next to the waterpump?
    Is the union too big (NPT is a tight fit) or is the pillar too big for the hose?
    May 2007
    762
    I went to a DIY store and bought some copper/bras item once … they had never seen a water pump of a '70 car …
Tags for this Thread
