Re: Granada MkII Estate - Removal and fitting of rear triangle window
most cars are like this so im pretty sure first you need to remove the main window, then the piece between the main and triangular window, before the triangle will come out
Check on the outer door frame where the track meets frame, there should be a screw on the top which holds it in place, and a bolt inside the door, undo these then you can remove the track and take glass out no problem
