Weber lever
Hi all,
i am fitting a sytec twin throttle linkage like this one in the link:
https://rover.ebay.com/rover/0/0/0?m...2F352426006405
i was wondering if you could tell me what type of lever will connect on to the rose jointed lever on the throttle? I have had a google, and a look on eBay I can’t see any which say they would fit. The weber ‘lotus’ lever looks like it has a round hole in it for a ball joint to connect to?
https://rover.ebay.com/rover/0/0/0?m...2F112463515727
I have twin Weber’s and no lever on them, only the balance lever with the screw on it and have no idea about this sort of thing. The sytec ‘kit’ doesn’t have anything in it for that either.
thanks
kris
Re: Weber lever
This is what I have:
Kris
Re: Weber lever
Contact Anthony at fastroadcars.co.uk he has the part you need
The Following User Says Thank You to Miniliteman For This Useful Post:
Re: Weber lever
You need a Male throttle linkage that fastens on the spindle with a hole in to bolt your rose joint to. Someone like Southern Carbs should be able to sort out your needs.
The Following User Says Thank You to Forest_rallying For This Useful Post:
Weber lever
These are very good value too
https://m.ebay.co.uk/itm/WEBER-DCOE-...-/113163184650
