shortening typ e rocket
best members,
i have a ford 4 speed type e rocket gearbox laying around, for a racecar butt the tail of the gearbox is to long. is there anybody that nows if you can shorten this type of gearbox?
i now you can do it with a t9 gearbox butt can you also do it to this typ gerabox?
i hope somebody can help me out!!
greetings
Louis Bolding
Re: shortening typ e rocket
Are you talking the whole overall length or just the gear lever extension? If the former then no (or at least not economically as its major engineering) - the latter, yes then possibly as its just simple cutting and shutting!
The Following User Says Thank You to katana For This Useful Post:
Friend of mine does this conversion for stockcar F2.
The Following User Says Thank You to Miniliteman For This Useful Post:
that was my plan too miniliteman!!
Hi, some of the Australian Escorts had a Type E fitted but with a tail housing that had the gearstick 50 mm forward, similar to the one pictured here http://www.oldskoolford.co.uk/ipb/in...-gearbox-help/
I do have one of the tailhousings and associated parts if you need better pictures
hey pikey15
can you send me some pictures? i like to see how people do it!!
Don't think MK engineering are about for the next few years, 🤤
does anybody now which gearboxes will fit a ford pinto 2.0? without modifications?
Any type E or Type 9 (from a 4 cylinder), BW T5, MT75's (although physically big), mazda 5 and 6 speeders (need a bellhousing adapter plate) plus plenty of rally / race derivatives.
Tags for this Thread
