Results 1 to 3 of 3
Thread: Zetec and Type 9 into Sierra - Propshaft woes
    Feb 2007
    Hillingdon
    2,107
    21
    So we’ve fitted a zetec with a 5spd type 9 into our Sierra using CVH engine mounts and a custom gearbox bearer. (Originally a 1.6 pinto and 4 spd)
    we had a single piece prop made to irradicate the rubber in the original 2-piece
    that vibrated
    i then bought a 2wd cossie 2-piece prop being told that was the one to go for, swapped over ends to the type 9, only to find out the prop is about 50mm too short, but
    i then out in the “original” prop that cam with the 4 spd, (I appear to have swapped to a type9 end at some point), this fits better, but still looks like it’s too short
    where am I going wrong? I thought all props were pretty much the same? Even the back ends seem different... the 2wd cossie back half is 10-15mm shorter than the ‘standard’ one I have
    is it my car? I.e. are the 3dr mk1 sierras different to every other Sierra out there?
    am I doing something wrong?
    My Project... Fiesta D-TEC
    Feb 2007
    Hillingdon
    2,107
    21
    Re: Zetec and Type 9 into Sierra - Propshaft woes
    I’ve had it suggested that a 7.5” diff is longer than a 7”, is this correct?
    Does anyone know how much shorter a type 9 gearbox is than a T5?
    Holland
    32
    252
    32
    I have also fitted a 5speed type9 with 2300 dohc into 3dr mk1 sierra.
    That was original a 4speed small prop.
    Just used the original 2 piece 5 speed prop, fitted with a new rubber piece that you slide in the end of the box.
    As far as I know the diffs are only wider 7''/7,5''
    Do you have the gearbox sitting in the same position, not a lot more forward in the sliders for the gearbox mount?
