Rattling noise coming from clutch
I seem to have a rattling noise coming from the clutch....when i touch the peddle lightly it goes away...its a 5 speed type 9 on a 1600 xflow.....any ideas .....ive attached a video of the noise
https://youtu.be/H3lq0TeuWrE
Re: Rattling noise coming from clutch
Sounds release bearing to me, but then in an extreme case it could be the gearbox.
The car changed gear ok ...should i try tightening the clutch cable more or is it a box out and bearibg replacement?
I would try the cable first....worked for me.
Otherwise as above,sounds like thrust bearing.
Cheers hopefully i can fix it.....the amount of problems ive had building this heap of crap is unreal
Welcome to the world of classic cars.....
I seem to have fixed it by tightening the cable up further but now i have horrendous vibration everytime i turn the steering wheel....it looks like the sump is hitting the steering rack...now i need to figure out how to fix that
Nice 1. Simple,cheap fix. Try lifting engine slightly at the mountings with washer or two then make a spacer to the required thickness....again this worked for me
