Results 1 to 20 of 20
Thread: Thank you
    Nov 2014
    South Lincolnshire
    11
    Thank you
    Just wanted to say a massive thank you to guys on here, specifically Graham and Erikmex, also RWD Jason who I don’t think comes on here any more. You all massively contributed to my first ‘big’ Pinto engine build which I’m delighted to say has been a massive success, it’s in the car and running and even before a RR tune is bloody fast! All the info you have willingly contributed I’m eternally grateful for and couldn’t have done without. Just want to do another one now!! 😂😂
  2. The Following User Says Thank You to IanSouthLincs For This Useful Post:
  3. #2
    9,204
    Thank you
    Always good to see appreciation being shown. 👍
  4. The Following User Says Thank You to alladdin For This Useful Post:
  5. #3
    3,641
    Re: Thank you
    Pleasure, glad its running well.
  6. The Following User Says Thank You to Erikmex For This Useful Post:
  7. #4
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    It certainly is, I know the venturis are too big and the jetting will probably be miles off as I’ve just got it running with the standard stuff my 48’s came with, but I can’t believe how hard it pulls and how free revving it is. I’m trying to be a bit careful with it for the first few outings but it just wants to rev! By the hell above 4000 it just takes off, it’s infectious!! ��
  8. #5
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Click image for larger version Name:	1F966A82-B07E-4421-89B6-0B2521DF58EC_zpsevlofqhm.jpeg Views:	127 Size:	135.5 KB ID:	83066
    Nestled in its new home 
  9. #6
    May 2007
    Vic, Australia
    662
    133
    Re: Thank you
    Always good to hear success stories and thankyous are something that people generally don't do enough of, so well done.
    The 3 have a wealth of information, I'm also glad that they have the willingness and make the considerable effort to help others and share their knowledge.
    Have you got a build thread/specs for your engine?
    Shaun
  10. #7
    3,641
    Re: Thank you
    Whats your choke size/jetting?
  11. #8
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Erikmex, still on everything the carbs came with from new:
    Chokes 42mm,
    Main jet 180,
    Air corrector 160,
    Idle jet 65F8,
    Emulsion tubes F7,
    Needle valve 250,
    Pump jet 45.
  12. #9
    3,641
    Re: Thank you
    That jetting and chokes will certainly give a good top end which might be good in your light car, i use 40mm chokes, F11 tubes, 170main, 55f9 idle, AC 180 and 45 pump jets. Ive tried a huge amoutn of e tubes and always come back to F11's. I used an Innovate wideband AFR gauge to get the fuelling right before a rolling road, best £150 ive spent.
  13. The Following User Says Thank You to Erikmex For This Useful Post:
  14. #10
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Thanks Shaun, I agree the willingness of guys on here to share findings and information is pretty incredible, not just limited to the 3 guys I mentioned, there’s been lots of contributors that have been more than happy to help a bloke build an engine!
    There is no build thread I’m afraid, for no other reason than it would have been way too long, it ended up taking me 2 years to finish as I was made redundant during the build and just had to shelve it while I got myself back on my feet.
    Brief specs are 202 block, decked 0.010” bored to 92mm. Wossner pistons and PEC 136mm rods. Injection head ported by me, skimmed for 44cc chambers. REC 45.5mm inlets and 38mm exhaust valves, k line guides. Cometic 0.051” head gasket. Kent RL22 cam (used for no other reason than I already had it, and would be an easy swap if I really didn’t like it!) double valve springs. Burtons steel flywheel. Weber 48’s on a Dave Brooks manifold and linkage.
  15. The Following User Says Thank You to IanSouthLincs For This Useful Post:
  16. #11
    3,641
    Re: Thank you
    Nice spec, RL22 is a good cam, im gona say 185-190hp.
  17. #12
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Cheers, if that’s the case I’ll be one very happy camper! Even now before a RR session it’s great, not much below 3500 unless on a really light throttle, but above it bloody flies, though I’m trying to be a bit careful as it’s very early in its life yet!
  18. #13
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Erikmex what does your car weigh out of interest?
  19. #14
    2,659
    268
    Re: Thank you
    Quote Originally Posted by IanSouthLincs View Post
    Can I have a guess at that question?
    I think I've heard Eric mention it to be quite light, so I'm saying 850kilo?
  20. #15
    3,641
    Re: Thank you
    870-890Kg
  21. #16
    Jun 2015
    Australia
    295
    Re: Thank you
    Hi erikmex have you run your car down the 1/4 mile cheers Mario.
  22. #17
    3,641
    Re: Thank you
    No mate, its a hillclimb / sprint / track car. 4.4 diff Quaife box.
  23. #18
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Hmm maybe I will get away with a more top end biased setup then, my kit car is just under 650kg
  24. #19
    Re: Thank you
    you might but in reality you will prob only gain a few bhp for a much big loss lower down
  25. #20
    Nov 2014
    South Lincolnshire
    11
    Re: Thank you
    Guys, can anyone recommend a RR centre to take my car to? I’m based near Spalding though will quite happily travel ��
