Results 1 to 3 of 3
Thread: removing wings
    Dec 2009
    Brentwood
    47
    774
    removing wings
    Whats the best way to remove my wings so I dont damage them to much as wanna refit em and get gaps better if I can????
    Old Fords Never Die, They Just Get More Filler!!!
    Mechanic oxb1l's Avatar
    Sep 2007
    A, A
    596
    Re: removing wings
    What kind of car ??
    I take it we are talking welded wings (mk1 2 escort )
    on a mk2 there are 3 bolts down the door pillar 10mm remove these ,welded on a mk1 onto the face of the pillar behind the door hinge area best way to remove the rest of the welds is using a spot weld drill and drill all spot welds on the wing rail as for other areas like bottom of the wing and front panel i would use a thin disc to grind the welds off
    its basically spend time and dont rush in, remove door and bonnet for better acsess the more time u spend on a good job u will be rewarded when refitting
    L8r Bill
    Dec 2009
    Brentwood
    47
    774
    Re: removing wings
    yea its a mk1 cheers bill
    Quote Originally Posted by oxb1l View Post
    What kind of car ??
    L8r Bill
