Remote servo
I am looking to fit a remote break servo to my mk2 Escort fitting it under the LHS of the dash the engine is a 2.0L EFI Pinto I was wondering where is the best place to fit the servo vacuum pipe on the manifold and what type of connector ie Elbow or Tee piece to use any help and advice will be appreciated especially with a photo
Re: Remote servo
it doesnt really matter where on the manifold or type of connector is used
Re: Remote servo
Do make sure that you have a one way valve between the manifold and servo though
The Following User Says Thank You to Duffer For This Useful Post:
Re: Remote servo
Do you have a number or email and I will email or WhatsApp you the photos as I have my remote servo under the dash on the passenger side. Will show you were I tapped into the manifold and then I just used a Y Piece to bring them together and connect them to the servo, this includes the non return valve
Re: Remote servo
Hi thanks Donnie my email add is billywhizz985@gmail.com as I am not on WhatsApp
Re: Remote servo
Hi Donnie I also forgot to ask you if you can show the brackets in the phot that’s holding the servo in place just to give me an idea of what I need before I fit mine thanks for you help
