DIS coil with for 'normal' sparkplugleads
Hello,
what DIS-coil can be used with std sparkplugleads?
I have a set of Magnecor leads for the BDA but the DIS-coil supplied with the ignition management system has a "post" inside each lead-connection ...
Thanks, Leon.
Re: DIS coil with for 'normal' sparkplugleads
i used zetec ones, normal leads were a nice tight fit inside and the boots were a tight fit over the towers
Thanks Graham.
Any idea if those Zetec coils are available with integral amplifier (x2)??
no they dont come with any amp(s)
