I got this for my project, but its not going to fit (I moved my bulkhead too far back).
These are popular for converting Escort Mk1/2 to power steering. There's loads of threads on here about how to do it. I have gone to the trouble of removing the steering lock and stalks. This leaves the column nice and bear for attaching the correct stalks from whatever you are fitting to. I would recommend that you fit a short piece of steel tubing with an inner diameter of 40mm over the bearing at the steering wheel end to secure the bearing. The original support for this is part of the steering lock that has been removed. The ECU is included and so are the connector plugs which have been removed from the Corsa along with fly leads. Also, the steering link with UJ's are included.
£50.00. I Can send with a courier to anywhere in the UK mainland for £10.00, or you're welcome to pick up from me in Writtle (near Chelmsford).
Call Sonny: 07505 780851.
