Results 1 to 8 of 8
Thread: Type 9 FMS cut down for crossflow. Will G/box work if I change to a zetec?
    Spanner Monkey QuIcKrAcK's Avatar
    Jan 2007
    LONGFORD IRELAND
    204
    As above. When I fitted my Type 9 I used a V6 version.
    So I had to shorten the first motion shaft and grind away some of the clutch splines toget it working behind the Kent. Pretty standard stuff.
    Now that I am thinking of changing to a zetec engine, I'm wondering will it bolt in and work??
    I think it will as it was "just" changed to align it with a standard type 9 box but you never know
    1700cc MK1 ESTATE DONE. MK1 2DR STARTED
    3,239
    Re: Type 9 FMS cut down for crossflow. Will G/box work if I change to a zetec?
    The Xflow / Pinto / Zetec crankshaft / flywheel relationship to back of the block is common across all those engines - not so the V6's hence the different 1st motion shaft.
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    I bought a couple of 8mm spacer plates to go between the bellhousing and gearbox and then cut the end of the input shaft flush with the bellhousing.
    No need to grind off any spline this way.
    Jul 2011
    herts
    502
  5. The Following User Says Thank You to davemk1 For This Useful Post:
  6. #5
    Jan 2007
    LONGFORD IRELAND
    204
    Quote Originally Posted by davemk1 View Post
    I never thought of that! I might search out a new fms and a set of those, thanks.
  7. #6
    Jan 2007
    LONGFORD IRELAND
    204
    I thought as much but dont like to assume.
    It usually leads to hardship in my experience....
  8. #7
    Quote Originally Posted by QuIcKrAcK View Post
    Surely that will just put you back to where you are now. Using a spacer will shift your gear shift back from what you have now. If it helps and you still want one I think retroford sell them.
  9. #8
    Jul 2011
    herts
    502
    I bought mine from retroford and although it does indeed push the box back, for some weird reason the original auto crossmember(auto shell) still bolted up to the floor using the original tunnel mounts without any other modifications. Go figure!!!
