I'm perhaps being a little thick but i need a little advice regarding rose joint on my 4 link kit.
I bought the body boxes and radius arms second hand and acquired a separate set of axle brackets later on so a bit of a mismatch,
a have determined that i need rose joint to connect the radius arms to the axle brackets but there are so many i don't know where to begin.
The threaded tube on the end of the radius arm accepts a 14mm bolt (albeit the thread is finer so i cant wind it in) would this be 5/8UNF?
The distance between the axle bracket holes is approx 31 cm and the bolt holes accept an M12 bolt (which i think is 1/2")
So i thought i needed a 5/8 x 1/2 rose joint, but then i need to space it out as its too narrow...
I then found something called a misalignment spacer but if i use these it will reduce the bolt size and i also need something that perfectly fills the 31cm gap
Can anybody advise what setup they have on their car?
ive managed to get myself proper confused
