help wanted water system lay out duratec 2.3
hi guys
i need some help with water system lay out for 2.3 duratec in mk1
thanks for any help george
Re: help wanted water system lay out duratec 2.3
Not sure if the 2.3 water system is the same as the 2.0, and 2.5, but I would be surprised if there was any difference.
These pics might help. They are from Dunnell Engineering and are for a system without heater.
Pretty much textbook install diagrams. One thing that is unclear, is rad with blank cap or a pressure cap as one or the other will change the top tank from a pressurised expansion type to the other - a plain header tank.
