Lightweight steel flywheel ohv kent
Burton Steel Flywheel part number FP253ARG
Used steel flywheel, 5.9kg total weight, flywheel purchased from Burton Power Engineering.
I recently removed this flywheel from my 1600 Kent 711M engine.
I have probably covered a couple of thousand miles with this flywheel fitted.
The flywheel accommodates a standard clutch.
The flywheel is fitted with clutch locating dowels and starter motor ring gear with 110 teeth
Comprehensive details of Burton Power part number FP253ARG may be found on burtonpower.com website. The flywheel is in good condition though there is some wear, commensurate with expectations of a used part. There is no scoring or overheating.
Pics of flywheel on eBay (I can’t download them to here. Incompetence most likely the reason).
*These flywheels sell on the BurtonPower.com website for £251.56 plus postage*
Note:
Item will be tracked via courier service.
Collection welcomed.
£165.00 plus postage
Many thanks
Paul
__________________________________________________________
Re: Lightweight steel flywheel ohv kent
I can supply pics via email or WhatsApp etc as the ebay sale ended, unsuccessfully, waaaah!
