Results 1 to 5 of 5
Thread: DTA S60 ECU wiring. Help with the 2 wires to the fuel Relay!
    Aug 2008
    Queensland,australia
    492
    Hi Guys I recently bought a DTA S60 ECU.
    There are 2 wires from the ECU loom (Red and Yellow) for the fuel Pump relay.
    Does anyone know how to wire up the Fuel Pump Relay with these 2 wires.?
    The Fuel Pump is a Bosch.
    Rob
    3,236
    Re: DTA S60 ECU wiring. Help with the 2 wires to the fuel Relay!
    DTA don't do looms so whatever it is, its aftermarket. If they are definitely the only two wires available then check continuity back to the plug - one should go to pin 3 this would be switched ground from ecu, the other should be ign. 12v connected to pin 31 and ecu ign. relay....... all as S60 wiring diagram. As regards relay connections the ground goes to relay 85 the power to relay 86 - I assume you know how to connect the pump to the relay?
    Aug 2008
    492
    Cheers I bought the ECU and loom directly from Alex at DTA Fast. There are 4 wires appear staying Fuel/ Fan Relays. The car has been carbies previously and the existing relays need to be fitted with these wires. I want to start the Fuel Relay wiring connection first. Cheers
    3,236
    Well the loom from DTA is a new one on me - you'd have thought they'd indicate loom colours on their wiring diagram to avoid this sort of confusion!
    Aug 2008
    492
    Yes agreed and it's a weekend too
