Dcoe jetting - anyone identify ?
I know it's a silly question really but just curious if this is s known configuration.
I just acquired a set of 3 prog. Hole 45 152 carbs. Possibly from a zetec setup which may explain
Chokes 36
Idles 60 f6
Main 110
Emulsion f11
Air 155
Any thoughts ?
Re: Dcoe jetting - anyone identify ?
110 main jet is very unlikely with a 60 idle jet.
Check if the main jets have been bored out.
Big idle jet tiny main, with 36mm chokes that would run massively lean on any engine
Yes I wondered if the big idle was to overcome zetec flat spot but 110 seems too small even for 1800. I will check if it's drilled.
That would make transition worse, it would go rich to massively lean
generally with zetecs the prescribed cure for the progression flat spot is to richen the idle jets, its the small main thats odd
Yeah, that would create a much bigger flat spot on transition, I doubt it would even run
i have just checked and they are not drilled - i'm wondering if someone has jet swapped prior to selling at some point................
anyway, i will be trying them during next few months on a pinto 2.0 self ported, fr32, compression raised by 1.25 head skim.
now from my research it appears the std supplied factory jetting should get me close.
i also see that its possible to drill the f6 to f8 and then f9 which will help.
and from what leon has said in the past i dont think the E tube will matter to much f11 / f16 ?
opinions welcome.
E tubes matter a huge amount, they alter the fuelling everywhere. Use f11 change idles to 50-55 ish if you have them, drill main jet to 150 (1.5mm) then see how fuelling is towards top end and potentially change AC to about a 180, getting the idle to main is the first and most important part.
i should have been clearer in that he said they are less important in a mild state of tune. possibly your actually agreeing by pointing at f11 as most seem to use f16
E-tube selection is crucial in any state of tune. I’ve always found f11’s work well in Pintos
The Following User Says Thank You to Erikmex For This Useful Post:
In my experience changing the emulsion tubes in a std engine with small-ish carbs (like 2 litre Pinto with std cam and twin 40's) doesn't change alot. With an engine with a FR32 and twin 45's it will matter (alot). Like Erikmex said F11's will work well.
The Following User Says Thank You to Miniliteman For This Useful Post:
Leon - apologies for the misquote 😊
(I read a lot of old posts the other night while having a bevy ! )
And thank you both for the ( valued) advice.
I do have both as it happens and was going to use the f16 but will go with the f11.
I used to always use f16’s in Pintos until I discovered how much better f11’s were across all revs, shame you didn’t post this in summer as I had some f11 vs 16 afr graphs from my car. I’ll try and find them on my laptop
