world cup lower or not....
hi all
i was jacking my gearbox up last night trying to establish the final position of the gearbox cross member and trying to get as much clearance as possible at the bulkhead. i noticed after cutting the tunnel out that the gearbox would not go any higher at the back. i presumed it was hitting the strengthening under the handbrake but it's not.
The front of the RetroFord sump is touching the steering rack. i have always presumed lower rack mount WCXM was for high suspension angles on forest rally cars but now i think i might need one. will that then mean if the car is very low that the steering arms will be badly angled?
anyone got a similar set up? any ideas?
Re: world cup lower or not....
why not just drop the box down at rear untill the sump is correct then fix box ?
i want to get as much clearance at the bulkhead as possible so inturn i wanted the prop end of the gearbox as high as possible. looks like i will just bolt it in as it is.
i jus t wanted to know if anyone else had come across this.
yeah matey I had a lowered rack it mine but it dose mess the geomatry about abit but for a road race you would'nt notice really
looks like i am going to have about 5 to 6mm clearance over the rack now the box is mounted. i can,t remember what an rs2 has with an ally sump on standard mounts but wanted a bit more really. We always want a bit more of everything me thinks!!
