Rally design windscreen and rubber!! Any troubles?
Hi all.
Wondering if any one has had trouble fitting a rally design windscreen and rubber? The fit doesn't seem the best, like the curve on the drivers side is bit off and the rubber doesn't seem a nice fit either needless to say it's cracked and in the bin! Either that or my shells bent! Lol
Anyone have any experience with them or any thoughts?
Cheers all! 😁😎
Re: Rally design windscreen and rubber!! Any troubles?
Can't speak for the RD ones but I got a full set(mk1 escort) from east Kent trim and the fit is great.
Cheers mate will try that I think
Mk1 or 2
Mine fitted fine from RD SCREEN AND RUBBER MK2
Mk1 screen from Gartrac was good, rubber from East Kent also good but their plastic chrome insert was rubbish, the "chrome" surface is peeling off at all 4 corners.
mk1 screens require a little bit of finesse to fit as the shells are always out, ive fitted loads and everyone was the same in same place
