Results 1 to 8 of 8
Thread: Braze or Weld, How?
    Racer Decade Plus User 900ss's Avatar
    Jan 2003
    In me Wyndymill
    3,336
    14
    Braze or Weld, How?
    I can't do either but want and need to learn how
    What is the difference between braze and welding ?
    Are there any good vids, dvds for a total beginner that explain from scratch ?
    Cheers Wyn ...
    Stuck in the 80's
    Back in Black
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: Braze or Weld, How?
    Find a local college that does evening classes. Probably a new course starting after Easter.
    Jan 2003
    In me Wyndymill
    3,336
    14
    Found a college but what is welding under?
    Cheers Wyn ...
    Stuck in the 80's
    Back in Black
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Usually under "Welding".
    Maybe under car maintenance, workshop skills etc. or maybe that particular college doesn't have the facilities.
    If you can't find one yourself, ring up your library. They will have all the info and are usually extremely helpful.
    Oct 2007
    middleton
    1,101
    64
    Quote Originally Posted by 900ss View Post
    Have you tried welding/brazing?
    Brazing is when the filler used to join the two pieces of metal together,only the filler is reached to melting point. Whereas in welding both the metal and filler are melted together.
    I bought myself a welder and taught myself using vids. I'm doing aluminium brazing at the moment,it requires patience in getting the correct heat on the metal
    Dec 2009
    Brentwood
    47
    774
    im not an expert but from the little bit ive done a lot depends on the rightwelder as a good gas welder makes life so much easier! Most plp teach them selfs
    Old Fords Never Die, They Just Get More Filler!!!
    Feb 2007
    cardiff
    517
    Brazing is pretty easy to pick up, not that I bother brazing very often. I went to a local college to learn to weld years ago, to be honest it was crap, everyone wanted to Mig so I kept getting stuck with an arc set, obviously this could just be my local college no real advice or tuition given just stand in a booth and have a go. I've since got to a reasonably good level by just getting on with it, get a load of offcuts and have a go, in my experience it's learning to set the machine up that's difficult once you've mastered that it gets easier and easier. Saying that I still hate welding upside down and vertical can be tricky too, I usually spot weld and overlap them as I go, endup with a really neat looking weld and less distortion. Hope this helps
    Jul 2009
    monaghan
    Check out http://www.mig-welding.co.uk/ the guys on there are very helpfull always good for a bit of advice
