Results 1 to 9 of 9
Thread: Help Please
    Mar 2013
    Knutsford Cheshire
    9
    Help Please
    Help Please
    Hi there
    my son and I have a mk2 Escort RS 2000 with a Cosworth YB 2wd standard spec engine.
    It has been laid up about 4 years and several months ago we made a start on resurrecting it.
    We have fitted a new roof to replace the old sunroof one which someone tried to weld and fill.
    However,apart from this ,we have had nothing but zero results in getting it to run right,as it once did.
    IT starts, but really badly over fuels and takes absolutely ages to get to run on 4 cylinders cleanly,the plugs are black sooted as you would expect.Plus it won't tick over at all,it just cuts out.😁😖😡
    We have replaced;
    Plugs
    Distibutor Cap
    Rotor arm.
    Crankshaft sensor
    Phase sensor
    Water coolant temp sensor
    Air charge sensor
    MAP sensor
    We are currently debating changing the Idle Speed Control Valve which we have cleaned adjusted and think it should be OK.
    Does anyone have any ideas ???
    Thanking you in anticipation.
    Oct 2015
    Essex
    347
    33
    Help Please
    Any fault codes showing ? Connect to ecu plug n led to 12v + ve and need check which wire pin u touch on earth for code readout
    It’s on web if it’s L1 ecu
    3,641
    Re: Help Please
    Is it a red RS from Scotland?
    Jun 2006
    3,670
    Re: Help Please
    Personally if I were you now that you have at least got it running Id take it to an expert. If its been sat for so long anything could have happened to the ECU or wiring. If its running weber management Id take it to Karl over at NMS in Derby as hes the closest to you. He should be able to diagnose whats wrong & hopefully get it running right for you. Its who Ive used in the past for mapping my cossie & hes mustard.
    Jun 2006
    3,670
    Re: Help Please
    Sorry, mis-read your location. Theres also Motorsport Developments in Blackpool who do weber mapping as well, altho Ive never used them.
    May 2004
    Norn Iron
    1,143
    Re: Help Please
    Quote Originally Posted by Headhunter50 View Post
    Help Please
    Hi there
    IT starts, but really badly over fuels and takes absolutely ages to get to run on 4 cylinders cleanly,the plugs are black sooted as you would expect.Plus it won't tick over at all,it just cuts out.������
    We have replaced;
    Plugs
    Distibutor Cap
    Rotor arm.
    Crankshaft sensor
    Phase sensor
    Air charge sensor
    MAP sensor
    Firstly, stop throwing random parts at it as that could confuse matters even more, especially if they are not correct parts for whatever chip/tuning might be on the car.
    If the plugs are fouled and old, bin them. If the plugs are fouled and new...bin them.
    What sort of mixtures are you seeing, just exactly how rich is it ?
    I assume you have put fresh fuel in it ? 4 years is a fairly long time. And checked filters etc.
    Have you actually performed some sort of spark test to see how strong the spark is on all 4, rather than just throwing parts at it ?
    Also, you might get some diagnostic help info here.
    http://www.bigturbo.co.uk/
    Oct 2011
    965
    Re: Help Please
    Check loom wiring
    I’m going to be removing my 380bhp engine from my mk1 in the next few weeks
    I’ve got everything for this conversion
    May 2004
    Norn Iron
    1,143
    Re: Help Please
    True...if it has sat for 4 years, the little mice might have found a home !
    Oct 2011
    965
    Re: Help Please
    It’s more to do with when the engine was removed and if the loom has been in storage
    The wires will have bent a certain way when in the engine bay for years and will become brittle
    If they’ve been bent opposite it has potential for breaks
    Do a continuity test for the whole loom
