Results 1 to 3 of 3
Thread: Water pump sorted...now heater has stopped!
    Jun 2009
    Oldbury, West Midlands
    11
    Hey guys,
    I posted my problems with a water pump swap the other day, thanks again for the help there, thats sorted but noticed my heater has stopped working, it was working fine before the swap, Ive checked fuses are ok, I did have a bit of coolant spray out the top hose on the heater matrix when bleeding but I had a plastic bag over the loom there, any advice would be much appreciated.
    Car is 1972 Mk3 Cortina originally 1600 XL now 2L pinto
    Thanks,
    Ant
    Re: Water pump sorted...now heater has stopped!
    Are you talking fan not working or heat not coming through. The latter could be an air lock maybe
    Jun 2009
    11
    Hey thanks for the reply, heater fan not working, pretty sure the matrix is ok, all pipes are hot once engines running, top and bottom of matrix pipes are hot, the heater itself is dead, before as soon as you turn the ignition on the heater fan would hum as it’s always on in the car....but now nothing!
    Cheers,
    Ant
