Results 1 to 17 of 17
Thread: Mk1 Escort - Bubble Arch Steering Wander
    Oct 2015
    Sheffield
    25
    Hi everyone,
    I have a bit of an issue with steering wander. Whenever I drive over a rough bit of road or rut, I seem to be fighting with the steering wheel to get out of the rut / correct it.
    I have fitted 8J wheels -12 offset, bilstein coilovers (not overly low) and a twincam anti Roll bar. This means I'm running quite a lot of caster and camber.
    I am also running roller bearing strut tops.
    The track rod end and tca look reletively parallel and of a similar length - no pretty confident this would not cause bump steer.
    Could I correct this issue by fitting adjustable top mounts/ will it make much of a difference?
    Many thanks
    Jamie
    3,641
    Re: Mk1 Escort - Bubble Arch Steering Wander
    Too much caster and amber will do that, aim for 1.5deg negative camber, 3deg caster and 0 toe. although -12 offset wheels are never going to give the best steering feel.....the issue could be the wheels
  3. The Following User Says Thank You to Erikmex For This Useful Post:
    Feb 2011
    ireland
    1,019
    241
    Quote Originally Posted by Jambob144 View Post
    Hi everyone,
    Many thanks
    Jamie
    Do make sure you have the correct mounts for the twincam arb
  5. #4
    Oct 2015
    Sheffield
    25
    Hi, yeah I have the correct mounts. I would upload a photo , but I don't think I can do it from my phone.
  6. #5
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    'Tramlining' is pretty normal with wide wheels and negative offset.
  7. The Following User Says Thank You to M11rf For This Useful Post:
  8. #6
    Mar 2016
    North Wales
    238
    15
    I have a similar set up and set mine to standard Mexico specs, 3 deg negative camber, not sure on castor as I don’t have a gauge for that, and 3mm toe in.
    If you have a quick rack, this will make it feel worse, hope this helps.
  9. #7
    3,641
    3 deg neg camber is loads, thats not std spec, std is about 0.5deg neg
  10. #8
    4,889
    Jamie,
    the ET-12 wheels will give a big scrub radius hence the wandering of the steering.
    Remedy is using struts with a higher KPI (kingpin inclination) but these are rare.
    Other fix is a toe in of say 3 mm, you don't list what you have now.
  11. The Following User Says Thank You to Miniliteman For This Useful Post:
  12. #9
    Oct 2015
    Sheffield
    25
    Thanks for everyone's input. I have measured borrowed a gauge and will measure the the camber and caster tomorrow and let you know
  13. #10
    Apr 2004
    4,346
    479
    Jamie,
    I make these hubs that have KPI designed into them...
    http://www.m11rf.com/product_info.ph...roducts_id=138
  14. The Following User Says Thank You to M11rf For This Useful Post:
  15. #11
    Oct 2015
    Sheffield
    25
    Ah cheers, I'll look I to the hubs. The camber was 1.5 degrees, caster is 6 degrees, toe in is 0.4 degrees.
  16. #12
    Oct 2015
    Sheffield
    25
    So I've been looking into your hubs. Will I need to correct the camber and extend the steering arms?
  17. #13
    Apr 2004
    4,346
    479
    If you buy any aftermarket Nissan Sylvia (S13 S14 S15) struts, they come with camber adjustable plates, i've never seen any aftermarket struts without the camber plates.
    The steering arms on the struts can be made standard length, but i think you will find that 20mm shorter is nice. It's not only good for drifting, but great for parking and 3 point turns. Even with a quick rack it's still feels positive and predictable.
  18. The Following User Says Thank You to M11rf For This Useful Post:
  19. #14
    Mar 2003
    Now over the pond North side
    3,540
    Quote Originally Posted by M11rf View Post
    Quick one M11rf, are you saying the sylvia has the same strut top mounting points? As in the fitting dimensions?
    Dazzle
  20. #15
    Apr 2004
    4,346
    479
    No... You'll either need to drill new holes in the body to take the Sylvia strut top or modify the Sylvia strut top to match the holes on the Escort body.
  21. #16
    Mar 2003
    3,540
    Cool, thanks
    Dazzle
  22. #17
    Oct 2015
    Sheffield
    25
    For further info, motorsport tools can machine the escort stub axles up to 12 degrees. I think the standard 2.8 struts are 7 degrees?
    Does anyone also know how far you can move the camber on the adjustable top plates from standard in 16mm?
    It would help in my calculations.
