Results 1 to 3 of 3
Thread: Extracting a tail end bearing bush out of a Type 2 gearbox
    Feb 2018
    Blaricum
    I would like to replace the tail end bearing bush with the gearbox in situ. Any idea where I can source a suitable bush puller?
    Seen them for American cars, but these are too large to fit through the 30mm inner diameter of the bush.
    Feb 2007
    Hillingdon
    2,107
    21
    Re: Extracting a tail end bearing bush out of a Type 2 gearbox
    I did this, I wouldn’t recommend it
    I did it with the gearbox off the car and still ended up having to remove the tailhousing in the end, not sure it was worth all the effort
    (This was a type9, but would assume quite similar)
    My Project... Fiesta D-TEC
    Nov 2007
    lincolnshire
    391
    I dont think they can be done in situ on these boxes. I have only ever done one and had to make up a threaded puller to suit. There was no way it could have been done on the car and like Adam I removed the tailshaft to do it. This was on a 2000e box which is similar. Getting the new one in wasn't much easier either as I recall.
