Mazda rx8 gearbox to xflow
Has anyone on here done this ?.....i know i need an adaptor plate for the bellhousing but can the speedo work via a cable like the type 9 ? ....and can it use a cable clutch ?
Re: Mazda rx8 gearbox to xflow
Speedo is electronic so no. I'm in the same position
People on here have made the cable clutch work I believe. I'm using the hydraulic one so can't help you with that one!
Pm a guy on here called Freddy686868 he does the adapter plates and could probably help you with the cable clutch.
