Results 1 to 12 of 12
Thread: Rev limiter
    Jun 2014
    Malta
    9
    Rev limiter
    Can anyone suggest a rev limiter for a xflow fitted with a Bosch electronic distributor. Please note my wife will read this so i need cheap.
    May 2007
    762
    Re: Rev limiter
    The cheapest is to lift your right foot faster then you want to !!!!!
    Aug 2015
    Leeds
    767
    Re: Rev limiter
    Quote Originally Posted by pwelly View Post
    after I bent a valve I fitted a accuspark limiter. It was £30 and a soft cut and adjustable and easy to fit but most are.
    Jun 2014
    Malta
    9
    Re: Rev limiter
    Reply from Accuspark. Not suitable for factory electronic ignition. Any other suggestions. Keep it clean.
    4,889
    Re: Rev limiter
    What do you mean with Bosch electronic distributor?
    What is the electronic ignition used?
    Cheapish rev limiters cannot handle the "extra" high voltage spike common with electronic ignition with dwell control.
    I always use the Lumenition rev limiters.
    Jun 2014
    Malta
    9
    Re: Rev limiter
    Miniliteman Check out Sticky at top of this section, how to convert crossflow to electronic ignition.Thanks for your reply.
    Aug 2015
    Leeds
    767
    Re: Rev limiter
    I’d have a gess and say what you did is not factory ignition, looks like mine on my pinto. That is a accuspark electronic distributor. And Lucas coil, mine has been on over 2 years and gets used regularly.
    sligo,ireland
    Re: Rev limiter
    I'm running a Bosch electronic ignition in my Fiesta using a VW rotor arm with rev limiter built in, it cuts in at 5750rpm iirc��
  9. The Following User Says Thank You to xr2inside For This Useful Post:
  10. #9
    Jun 2014
    Malta
    9
    Re: Rev limiter
    Do you have a part no.or VW type, year, etc, for the rotor arm.
    Thanks for the reply.
  11. #10
    Re: Rev limiter
    surely 5750rpm is too low for any sort of tuned x/f?
  12. #11
    Jun 2014
    Malta
    9
    Re: Rev limiter
    VW rotor arms range from 5400 to 7300.I just need to know which VW rotor arm will fit a Bosch electronic distributor with a side entry cap from a Valencia engine .
  13. #12
    Spanner Monkey Arieke's Avatar
    Dec 2008
    Belgium, Zandhoven
    438
    Re: Rev limiter
    I have a omex pro relimiter for sale if it would work. It worked on my pinto with distributor.
