C20XE rear cam cap exhaust side
Hi folks, I need a rear cam cap for C20XE on the exhaust side that the distributor bolts to, anyone got one?
Thanks in advance
Re: C20XE rear cam cap exhaust side
You cant swap a cam cap from another engine, they are line bored and specific to each engine, you would have to be very careful making sure alignment and clearances are measured properly if using a random one.
I know cheers, It doesnt matter with what im doing, it's getting cut down for clearance and won't have a camshaft going through it, will just have a core plug in there its just mine is missing don't know where it is, think it might've got slung
Ah, youre cutting the cam for fitting in an escort? remember the little oil hole when you machine off the dizzy drive housing.
Thats the one, just not in an escort though ive done all the other bits its just the rear cam cap holding me up now
Sorted now
I might get round to make a build thread on the car
