Another strange rattle
Anybody have an any ideas whats causing this rattle
..it seems to go away when i rev it but on idle its loud
https://youtu.be/AQ3tiD4DsB8
Re: Another strange rattle
Someone at work reckons its a broken valve or valves but surely if it was then it would get louder the more i rev it.....the youtube link above is of the noise
Water pump bearing? Remove fan belt a try then.
Alternator bearing? As above.
Clutch thrust bearing? Dip the cluch and see if it still there.
The Following User Says Thank You to yellowtaxi For This Useful Post:
Cheers....ill try the taking the belt off tonight...it doesnt make any difference pressing the clutch...but the pump was a new old stock i bought and its funny u mention that as thats the newest part
A long shot but remove the vac pipe going to the block breather box, put your finger over the hole in the end of pipe while it's running see what happens.
The Following User Says Thank You to Colr6 For This Useful Post:
Sorted guys ... thanks a lot for your help.....turns out its the flaps on the carb thats vibrating and causing the noise...i tried both methods mentioned first so just need to reconnect them and loosen the clutch a bit as i tried tightening thst a bit more.....totally chuffed now as i couldnt bare another strip down
