Results 1 to 28 of 28
Thread: Zetec inlet manifold drawing
    Jul 2005
    Australia
    149
    Hi All.
    I want to laser cut an inlet flange for my custom Zetec inlet manifold but was wondering if someone has a PDF drawing (or similar) to save me measuring one from scratch?
    Paul
    9,200
    Re: Zetec inlet manifold drawing
    someone posted one once, do a search. ive got a drawing i made, they fitted well . its however on a3 paper so i will have to see if i can scan a3 to pdf. let me know if you need it
    Jul 2005
    Australia
    149
    HI Mate
    Yes, I found the thread after I posted - DOH!
    Thanks for the reply.
    Paul
    Brum Town
    1,822
    26
    i did that if you need a DXF file for a laser/wire eroder let me know
    Jul 2005
    Australia
    149
    Email sent........
    Paul
    Brum Town
    1,822
    26
    right click save as. *should work* never really used the FTP before
    http://itsalmosttime.co.uk/lath/ZETECFLANGE.dxf
    9,200
    works fine.
    Jul 2005
    Australia
    149
    HI All
    Thanks for the response but printing either the above DXF or the PDF drawing (from another post) does not match my Silver Top inlet gasket.
    There is a big discrepancy between the port alignment with the mounts and the actual mounting point dimensions also.
    Is it just me? Has someone else actually used this drawing for an actual flange?
    I will update with what suits my OEM manifold gasket.
    Also, I will alter the port dimensions to match the oval shape and ignore the injector relief.
    Paul
    9,200
    i will compare to my tried and tested drawing. mine has no injector reliefs.
    Jul 2005
    Australia
    149
    OK, after a few hours in solid works I have a drawing to reflect the Silvertop inlet manifold with modified ports.
    I cannot upload files - is there a prob with Windows 7 etc???
    Paul
    Brum Town
    1,822
    26
    seemed to fit the engine ok?
    Jul 2005
    Australia
    149
    That flange in your pic does not match any of the drawings found on this forum or the DXF file downloaded from the previous post
    Paul
    Feb 2007
    Hillingdon
    2,107
    21
    is there anything drawn up for a cvh?
    i tried having a look, but couldn't find anything
    My Project... Fiesta D-TEC
    Oct 2009
    nottingham
    174
    i drew this one and have it fitted to my 2l silvertop now with rover 220 turbo inlet on not the cvh one as drawn, had to open 1 of the holes out a little tho......
    dont know how to do the download clicky thing tho i have the files without cvhports too as its just overlayed on this pic, i can email if its needed??
    Jul 2005
    Australia
    149
    Ah, I doubt the uploader likes Windows 7 so resorted to XP on the laptop and all OK.
    Files below of what I have measured
    Attached Thumbnails Attached Thumbnails zetec inlet flange final.jpg‎
    Attached Files Attached Files
    Paul
    Brum Town
    1,822
    26
    musta got versions confused in the sands of time, i've knocked up a couple of revisions, but this was like 3-4 years ago
    Feb 2007
    Hillingdon
    2,107
    21
    Quote Originally Posted by Adam B View Post
    anyone got one for a cvh inlet?
    please?
    Aug 2018
    Poznan
    does anyone have dwg drawings for intake manifold flange for ford zetec engine? Links above doesnt work
  19. #19
    3,237
    I've just drawn up 'Zetec RS's' pdf drawing in CAD and its mostly correct - the dimensions across the bottom don't add up to the dims across the top - there is a 1mm error somewhere and the top line is a bit 'guestimated as nothing to set it out........ but it looks ok!
    If you want the files, I can post them up as AutoCAD .dwg or .dxf - but take no responsibility for them working or bolting to an engine ! ! !
  20. #20
    Feb 2009
    kansas city, mo
    I'll take that if you still have it, I'll mill it up and let you know how it fits. Thanks in advance
  21. #21
    3,237
    Quote Originally Posted by inis View Post
    Took a bit of finding - both DXF and DWG formats - sorry its on the piss - only way to get it on an a3 sheet!
    EDIT ........ Ah! - both file formats not allowed for attachments ! ! ! Send me an email address and i'll sent that way.
  22. #22
    Feb 2009
    kansas city, mo
    Lol I need 10 post to send private messages. Member for 10yrs lol. I'll edit this later. inis1981@gmail.com
  23. #23
    3,237
    Sent - hope you get them!
  24. #24
    Oct 2012
    Denmark
    Hi katana - could also please send me the dxf file - casper.kristiansen(at)gmail.com
    Thank you :-)
  25. #25
    3,237
    Quote Originally Posted by Keinicke View Post
    Thank you :-)
    You have mail!
  26. #26
    Sep 2022
    Devon, uk
    Good afternoon katana, could i possibly grab the dwg andxf files aswell please.
    Biscuit240@googlemail.com
    Many thanks.
  27. #27
    3,237
    Quote Originally Posted by Biscuit240 View Post
    Many thanks.
    Email sent!
  28. #28
    Nov 2022
    Warrington
    Could you email it to me please
    Matt@top-dj.co.uk
    thanks
