Sierra Cosworth 2wd White 1990 HPI clear
This car was bought and was previosly sotred for 2.5 years or more and was purchased to put back on the road. Been sitting in a garage doing nothing.
Has just come back and only covered 250 miles since rebuild by A1 rally sport
It had new block due to crack and new rings,new bottom end bearings head was all checked and has been prted and polished all guides and valves spot on was bulit up with group a gaskets etc.The box was difficult to change up and down in number 4 common on these so had third and fouth replaced with new syncros. It was then taken for mot and failed on a couple of minors and needed a small amount of welding to rear chassis near the spring mount common on these otherwise looking all solid underneath. the steering coupling had movement on it this was also dealt with. They also serviced it and put new cambelt and tensioner on it. Now runs sweet as a nut and needs small amount of running in then the boost can be turned back up to 14psi as has stage one chip filter and exhaust. Runs on a t3 that all looks in good fettle and was told uprated.
Has koni uprated suspension and standard wheels other than that all looks stock and not pissed about with or chaved up. Good honest clean car ready to rumble and has no faults smokes rattles of bangs. 20 years only so expect a couple of rust spots on rear arches and car parks pin dents nothing worth worrying about.
Comes with about 5 months tax and 11 months mot.
Looking for around £3895 no pxs please as already have a new car
Car situated in Bedfordshire for viewing
