what map sensor
which one should i get to run with my omex? there are quite a few 3 bar ones on ebay but the price varies alot. has anyone had any issues with the cheaper versions?
cheers
Re: what map sensor
also can anyone recomend a good universal 3 or 4 wire lambda sensor ?
Re: what map sensor
omex sell the right lambda for about £50
i know, i've had to buy two
oh... is your loom for a 3 or 4 wire lambda?
mine was originally a 4 wire, but they've now gone to 3 wires, so i had to speak to omex about which wire i could leave out.
Re: what map sensor
spoke to omex and they said the lambda is £80 iirc and i can get either 3 or 4 wire i only need 3 but i can just joint the unused wire to one of the others
Re: what map sensor
Narrow Band Lambda Sensor - OMEM2301 - £55.00
Lambda Wiring Connector - £5.00
Postage (UK Mainland) - £4.50
contact: alanb@omextechnology.com
