Results 1 to 7 of 7
Thread: heater bubble gutter? do they do a patern part to repair?
    Dec 2009
    Brentwood
    47
    774
    The gutter that runs around the bulkhead heater bubble, does anyone know if that do a repair panel for this??? as my mechanic has welded it up flat but even though it will be hidden mainly behind the engine I'm not really happy with it like it is and after doing all this work dont wannt this to spoil it
    Help!!!!
    Old Fords Never Die, They Just Get More Filler!!!
    Mechanic oxb1l's Avatar
    Sep 2007
    A, A
    596
    Re: heater bubble gutter? do they do a patern part to repair?
    i've not seen a repair panel for this but when i done my own one a long time ago i had to remove the bubble and i put a section in that i bent myself (13 yrs ago as a sheetmetalworker easy to make bends)ask local machine shops if they have a bender that could do such a small fold or even something a bit bigger and buff it down to the size required
    Bill
    The only thing that comes close is the bulkhead top panel from 'Expressed Panels'. Good but not cheap! Espeacially as you would be cutting a small part out of it to use.
    Just make up a section from flat sheet with bends/folds as required to make it match the original. That is what I did.
    Dec 2009
    Brentwood
    47
    774
    thanks boys was hoping for a repair panel cuz dont know how good his sheet metal skills are
    Quote Originally Posted by Marigold View Post
    Racer Decade Plus User x-pack's Avatar
    Mar 2006
    Leyland, Lancs
    2,102
    169
    or have a one in a million lucky find like i did! Found this bloke selling the entire bulk head on ebay for 20! ...and it was just down the road from me!!!
    Just be careful not to rip up the original dome when you prize it off and you will be fine. It's a piece of piss to repair the bulk head once that's off
    I'm going to pull your head off because i don't like your head!
    Nov 2008
    Adelaide, Australia
    1,440
    98
    Twin Cam Services
    41 McCulloch Ave
    Seaford
    VIC 3198
    Tel: 61 3 9786 4711
    Fax: 61 3 9786 8263
    They do a one piece repair panel for the area under the heater bubble (if that is the bit you are talking about). Equivalent to 90 pounds from memory.
    There is a pic of it in the first few posts of this thread....
    http://rsmotorsport.com.au/forums/viewtopic.php?t=834
    World Champion Decade Plus User Pitstop's Avatar
    Apr 2003
    Essex
    64
    6,651
    88
    I've got a heater bubble with a section of bulkhead still attached. You have PM.
