Results 1 to 31 of 31
Thread: Which duratec engine/sump for Mk2 Escort rally car
    London
    35
    Hi There Ive just found this site and Im looking into converting my Pinto to 2Lt Duratec in the next few months.
    My question is which engine is it best to start with,Im not looking for mega power somewhere around 200 bhp will be good to start so do I need the ST150 engine?I intend to run it on throttle bodies & decent exhaust manifold but hoping not to too many engine mods to start with.
    My other question is this :- Does anybody make a sump wet or dry sump which allows the 2lt Duratec to be dropped straight into a Mk2 Escort without changing the WCXM for one with lowered steering rack mounts? And finally can you fit a Duratec into a Mk 2 Escort without modifying the bulkhead?
    Thanks in Advance
    Martin
    Racer mervhill's Avatar
    Oct 2005
    In the clouds
    3,000
    22
    Re: Which duratec engine/sump for Mk2 Escort rally car
    Hi Martin,
    If it were me doing this, which it very much will be in a few years' time, I'd be speaking to Steve Broughton at SBD Motorsport...... www.sbdev.co.uk
    They do everything you need to transplant a duratec 2.0L into a MK2 Escort, from the chassis mount kit, to the bellhousings, exhausts, throttle bodies, ecu, loom etc. The 2.0L is an excellent engine, and has more potential than the 2.3 according to Steve who has done back to back development on both and chosen to go with the 2.0L himself. Can do several kits, anywhere from a basic throttle body package giving 203bhp, add cams and you have 214, add some pistons and rods and there's 235! Basically can just continue to add bits to it all the way up to 290+bhp. SBD also do Escort specific dry sump kits for them too.
    My brother has one in his car, the all singing all dancing 290+bhp version, you can see it in action in my videos..... http://www.youtube.com/user/glendowner
    Also, have a look at his thread on here to see how simple the install is..... http://www.turbosport.co.uk/showthre...c-installation You'll see that he went from N/A cossie too, which is pretty much the same swap you'll be doing in most respects.
    Give Steve at SBD a call on 0208 391 0121, he's always ready to answer any questions you may have regarding the conversion. Most of the parts were developed using my brother's car as a base, so it's all tailored for the MK2 escort too.
    hope this helps, and from my point of view you're definitely making the best choice for conversion.
    Tyre Kicker jdrally09's Avatar
    Mar 2009
    saltash
    22
    Oct 2005
    In the clouds
    3,000
    22
    The torque curve from those webcon kits is awful, the power curve isn't particularly smooth either. Compare it to the SBD graph.... http://www.sbdev.co.uk/Duratec/Durat...ttle%20kit.htm
    Mar 2009
    saltash
    22
    Agree. I have a 2ltr Duratec from JRE race engines. 280HP. He has worked closely with SBD in the past, and probably biuilds the best engines in UK. Now building 2.5 ltr Vauxhalls.
    Oct 2005
    In the clouds
    3,000
    22
    Yeah, the JRE engines are pretty awesome. Steve builds the best Duratec 2.0L in my opinion, can certainly claim the most horsepower and torque from one. He doesn't touch the 2.3 or 2.5.
    Mar 2009
    saltash
    22
    How much would your man charge for a 2ltr Duratec. Complete turn key motor.
    Oct 2005
    In the clouds
    3,000
    22
    Honestly mate I've never priced one up, and I wouldn't want to guess. However if you're talking about a basic stock engine on throttles for 203bhp, then you're looking at approx 3.5k without the donor engine to get it in the car. Again, like I say though, that's a guess.
    London
    35
    Thanks for the replies,I will give SBD a call. Id still like to know whether any sumps clear the standard MK2 world cup crossmember and which engine is the best base.
    Thanks again
    Oct 2005
    In the clouds
    3,000
    22
    Quote Originally Posted by vataman View Post
    Thanks again
    With the Duratec you'll need to chassis mount anyway, as the engine mount points are in the wrong place to use a WCXM with mounts. So you use a cross member without the mount positions. My brother has a pace dry sump on his using this setup, and I don't think he needed to modify the cross member at all, but I will check.
    Dec 2007
    Dubai
    1,716
    29
    Did a fair bit of research on this to fit the Duratec in the MK1. First and foremost, I was looking for bang for the buck. Both Dave Colledge at Retro-Ford and Steve at SBD, do great turn key solutions for the Duratec into the MK1 or MK2, however IMHO they are both quite expensive.
    I have been building Duratecs now for 6 years and for me the best value and quality for Duratec's has always been at Raceline. Pete McEwan, the engineer at Raceline has supplied and built many solutions for the Caterham factory and race cars, he is an excellent engineer and never exaggerates his product. Currently Pete is getting 310bhp on Mountunes Dyno on a 2.3. Caterham now use Racelines product instead of Cosworth on pretty well all their cars, including their integral dry sump, which I am using. However this will not fit a standard cross member.
    The only limitation with Raceline is that they are not geared up for the Escort, so there are other options to be considered. Roger Carroll of Adelaide AUS, has a nice solution to put a Duratec on a standard crossmember, which he is currently racing to great success, with about 290bhp. He also does a bell housing, water-rail and dry sump pan to go with the standard cross member and a RX7 gearbox. Really is well worth looking at this, if you don't want to chassis mount.
    If you look at my resto thread you will see that I have gone with the Retro Ford WCXM and mounts, with hindsight, I would chassis mount it, but if I was doing a relativly low powered Duratec (less than 240bhp), I would go with the Australian solution.
    www.gulfpetrolheads.com
    Mechanic roosie's Avatar
    Jan 2003
    Brandon Norfolk
    901
    Aug 2009
    Australia
    106
    Yes, I can provide you a dry sump to drop the Duratec straight into a standard Escort engine compartment on original crank centreline and back-of-block using the original round Pinto rubber mounts. The spin-on oil filter still clears the crossmember so you don't need to remote mount it.
    I can also do a water outlet elbow/side pipe which doesn't need any change to the firewall.
    If you want more details, photos etc etc, please contact me on jrprmc@bigbutton.com.au
    Roger Carroll.
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    36
    1,131
    apologies for digging up an old thread but im looking at which engine would be best for my mk1 escort,
    i thought a 2.0 vauxhall XE was the way to go but then somebody on another forum mentioned the duratec.
    Im after a good reliable 200bhp without spending a fortune, what are the pro's and cons over each engine and which would you use?
    which duratec do i need as a starting point? ive been looking them up online and there are loads of variants
    regards, Steve
    ST150 engine 2008 on with the high flow head casting number RF3S4G or RF6S4E this can be worth 10+15 bhp over the early head
    Dec 2007
    Dubai
    1,716
    29
    Yep, late model 2.0 (2008 on) all of which should have the Hi-Port head, throttle bodies and rest stock will give you about 200bhp.
    Raceline Cams and springs will take you up to 226bhp on stock rods and pistons, if you put valve cut outs in them.
    Jul 2012
    cambridgeshire
    36
    1,131
    cheers guys
    Jul 2012
    cambridgeshire
    36
    1,131
    can i use a year 2009 st170 bottom end? or are they completely different engines
  19. #19
    Jul 2006
    bristol
    11,509
    902
    That's a Zetec buddy completey the wrong engine.
    The ST170 is badged as a duratec bits it's just a fancy Zetec still a good motor but not a duratec.
    You should be able to hit the 200hp make from a standard duratec if you get the right engine and spend the money on the right inlet/exhust management
  20. #20
    Jul 2012
    cambridgeshire
    36
    1,131
    ah right, got it! ill ignore the st170 then as its the duratec im after
    ill keep my eyes open for a cheap st150 (if theres such a thing)
  21. #21
    Racer Forest_rallying's Avatar
    2,037
    They did n`t make the ST 170 in 2009. There are plenty of Breakers on E Bay with Complete Duratec Engines from 200.
    The big expence comes with the parts for the conversion, Sump, Bellhousing, Water rail, Management etc.
  22. #22
    Feb 2014
    Brentwood, Essex
    Hello everyone,
    I am new here and this is my first post.
    If anyone is interested I can supply new Genuine Ford parts and Duratec engine parts for both 2.0 and 2.5.
    I have new donor engines and standard parts at excellent prices. In fact if there is any Ford part you need just contact me and I will give you the best prices guaranteed.
    We at Mountune have the best Race & Rally Ford Duratec engines in competition and if I can be of any help to those of you interested in runnning Duratecs in Mk1/2 Escorts just ask.
    Regards
    Derek
  23. #23
    Spanner Monkey Turbosport Subscriber Jimmythedimmy's Avatar
    Jun 2007
    Norfolk
    35
    401
    Thanks for the info Derek, I am assuming you work for mountune then.
    what is the price for a 2.5 I4 non balance bar short engine?
  24. #24
    Dec 2007
    Dubai
    1,716
    29
    PowerTorque Engineering can supply you a brand new (correct spec) 2.0 or 2.5 for around 1450-1550+vat, that is where most of the engine builders get theirs from
    www.powertorque.co.uk
  25. #25
    Jul 2012
    cambridgeshire
    36
    1,131
    Welcome to the site Derek, i'm sure i'll have plenty more duratec questions to follow later on
    i want one in the mk1 escort but actually know very little about the engine and whats involved
  26. #26
    Aug 2009
    Australia
    106
    Hi Derek,
    I do a full kit of parts to fit the 2.0l Duratec into Mk1/2Ecorts without needing to change X member or firewall.
    It has been race proven over 4 seasons now with 100% reliability.
    Parts include: Water outlet elbow, engine mounts, dry-sump kit, dry-sump tank, oil filter/cooler mounting adaptor.
    I have recently upgraded my dry-sump kit to include the latest most compact and efficient pump available, plus mounting bracket, hoses, belt, pulleys and fasteners.
    Please contact me at my (new) email address jrprmc1@bigpond.com and I will be happy to send you full details with pics. etc.
    Cheer from a fellow Escort lover,
    Roger.
  27. #27
    Jun 2015
    Malta
    Putting a zetec turbo on my escort mk2
    Hello,
    This is my first post here. I am currently building my escort and have just bought a mondeo silver top to throw in my cort! As these engines have some major problems about the oil pump I decided to built it up with a dry sump.
    Is there anyone here placed on or similar zetecss(duratec) in an escort mk2 or mk1. If yes, and obviously with a dry sump which make did you fit and if there has been any alterations in the sump, cross member or the car itself.
    P.S. The engine is going to be chassis mounted. The engine support which were with the crossmember are removed already.
    Thanks and Regards
  28. #28
    Dec 2007
    Dubai
    1,716
    29
    I used the Raceline integral pump Dry sump to good effect, by far and away the cheapest option and no external belts to worry about. Have a look at my thread for details and pictures
  29. #29
    Aug 2009
    Australia
    106
    Click image for larger version Name:	Dry Sump Kit IMAG0405.jpg Views:	468 Size:	142.5 KB ID:	75628
    This is my full dry sump kit which fits with OE cross-member on standard round Pinto engine mounts; no body or chassis mods necessary.
    Contact me for more info. at: durescort@gmail.com
    Regards,
    Roger.
  30. #30
    Sep 2006
    Bedfordshire
    330
    33
    How much would this work out shipped to the uk?
    Conversion, tax, shipping etc etc ?
  31. #31
    Aug 2009
    Australia
    106
    Quote Originally Posted by doughman View Post
    Price in AUD $2190 + $130 (est) for shipping = total $2320 or 1095 UKP.
    Conversion fees : see your Bank.
    Taxes : Check with your Local authorities.
    Roger.
