Results 1 to 14 of 14
Thread: Throttle cable linkeage
    Jul 2017
    Povegliano veronese
    27
    133
    70
    Just bought Burton mk2 escort pedal box, is there a throttle cable for that kind of linkeage? Cable end with a ball, but it can't pass through the small hole of the pedal... Is there anything I can't do avoiding to cut and welding a brand new thing?
    Thanks.
    Dec 2011
    Cowdenbeath
    400
    32
    Re: Throttle cable linkeage
    Standard throttle cable should fit as it's the same throttle pedal
    Jul 2017
    Povegliano veronese
    27
    133
    70
    yes it should, but how can I put the little ball at the end of the cable, inside the hole of the pedal? one side of the hole is big enough (right size for the ball), the other is way too small (wich is correct to stop the cable), so I have to cut the side of the hole on the pedal and let the cable pass, but it makes no sense to cut it, also because the side of the hole on the pedal is really thick, and by cutting it, it would become really weak...
    It's out of question to separate the carburettor side linkeage from the cable, also because they should be pressed togheter and it would never return to be strong enough.
    I can make it by welding something stronger on the side of the pedal (like a nut), cut the side of the nut, let the cable with the ball enter and it works.
    But like I said, make no sense to modify something new, which is made for that car/engine. So I was wondering if I'm missing something.
    The car was an OHV 1.3, so the linkeage was different (female/female), but I also have original pinto engine throttle cable, with "male linkeage" (the little ball) on pedal side, and female on the other (carbs).
    Mar 2008
    west bromwich
    1,861
    Try speedy cables they can make up a y end you need
    Jul 2017
    Povegliano veronese
    27
    133
    70
    Thanks, but unfortunately I live in Italy, and only shipping it here it would cost me like 25£, it's easier to modify del pedal.
    4,889
    Photo?
    Jul 2017
    Povegliano veronese
    27
    133
    70
    https://www.burtonpower.com/throttle...6-fka1015.html
    look like this, but with a ball at the pedal end.
    ps: the ball is like this https://www.burtonpower.com/throttle...0-qtc4028.html
    4,889
    Photo of pedal and pedalbox?
    Did you buy a LHD pedalbox?
    Jul 2017
    Povegliano veronese
    27
    133
    70
    Brk003 is the code, I don't think there is any difference between Lhd and Rhd
    The pedal box fit perfectly, the problem is the throttle pedal.
    Jul 2017
    Povegliano veronese
    27
    133
    70
    https://photos.google.com/share/AF1Q...UySVpleV9JbWJR
    you should be able to see, tried to post it here but didn't work
    9,204
    Quote Originally Posted by Enea View Post
    I posted a throttle linkage to Tenerife recently (1kg). £13 signed for Royal Mail
    Shout if you need help shipping etc 👍
  12. The Following User Says Thank You to alladdin For This Useful Post:
  13. #12
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Cut a cable sized slot from the top of the pedal down to the hole.
  14. #13
    Jul 2017
    Povegliano veronese
    27
    133
    70
    thanks to everybody, like I said in the first post, I needed to know if there were a std ford cable on sale for that kind of throttle pedal, It seems clear that it's not, so I'll weld a plate to the top of the pedal with the right hole to suit the cable and the ball, and it won't give any problem.
    Thanks again.
  15. #14
    Oct 2008
    italy
    471
    21
    sent you a private message
