Results 1 to 11 of 11
Thread: Diff Ratios - Tarmac Rally
    Nov 2008
    Adelaide, Australia
    1,422
    95
    I currently have a Hilux diff in my Mk1 Escort that has a 4.88:1 ratio. At 8000rpm that gives a theoretical top speed of around 215km/h (from memory). During tarmac events the most i have seen in reality is 196km/h. The car usually struggles at high speeds especially if it is even slightly uphill.
    I am considering whether i need to increase the diff ratio to 5.1 or even 5.3 for more punch out of corners, better pull up hills but at the expense of a little top speed.
    What ratios are others using in their tarmac rally cars?
    Is there any mechanical reason not to do this? Does the diff get weaker at higher ratios?
    23,819
    234
    Re: Diff Ratios - Tarmac Rally
    what you call a higher ratio, most of us over here refer to as being a lower ratio, it might be numerically higher but gives less speed so we call it lower! anyways, yes your correct as you get lower (uk) the pinion gear gets smaller and has less teeth so the load isnt spread as far so they do become weaker
    Nov 2008
    Adelaide, Australia
    1,422
    95
    ...as you get lower (uk) the pinion gear gets smaller and has less teeth so the load isnt spread as far so they do become weaker
    do ppl use as LOW as 5.x in tarmac rally? Soft tyres, aggresive LSD etc
    Jun 2006
    kilkenny, ireland
    522
    I use a 5.1.
    Tarmac Rally car, 13" wheels, sticky tyres, 1600cc 4age engine, type-9 straight-cut clubman gearbox.
    Nov 2008
    Adelaide, Australia
    1,422
    95
    Quote Originally Posted by muckerbarry View Post
    I use a 5.1.
    Tarmac Rally car, 13" wheels...
    I have 15" wheels so if my brain is in gear correctly then I would need greater than 5.1 to have the same overall ratio as you (assuming the same gearbox ratios). Hmm I wonder if a 5.3 is in the relm of Ok then...
    Jun 2006
    kilkenny, ireland
    522
    In theory yes, but it depends on a lot of factors....
    For example my engine has a redline of almost 8000rpm, if however i had a pinto with a redline of 7000rpm then my diff would be too low.
    Gear box ratios also comes into it, do you have a 5 speed with an overdrive 5th? or a 4 speed with a 1:1 4th gear?
    How often do you actually get to drive it flat out in top gear? I can count on one hand the amount of times my car has hit the limiter in top gear.
    Its not an easy question to answer unfortunately!
    I support TS Decade Plus User
    wildo105e's Avatar
    2,801
    99
    A look on eBay and there are atlas ratios of 5.3 and 5.8 are available from quaife. So that would suggest there is a demand for these. I assume they are out there for a Hilux.
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    785
    I run the same diff as you (Hilux with Kaaz LSD) and I had a 5.3 in it but have gone up to a 4.315 as I do circuit racing not rally
    So there def are these ratios available for the hilux. If you were in melb I'd swap you for mine
    Matt
    Nov 2008
    Adelaide, Australia
    1,422
    95
    Quote Originally Posted by Matt75 View Post
    I run the same diff as you (Hilux with Kaaz LSD) and I had a 5.3 in it but have gone up to a 4.315...
    Is the 5.3 still kicking around? If I change ratio I will build a separate unit so that I have both 5.1/3 and 4.8 available to me.
    Mar 2011
    Melbourne
    785
    Yes, im looking to get another one too to replace it but unsure whether to go 4.8 or 4.1
    Australia
    35
    16
    swap me the 4.88 for a 5.36
