More help from the masses needed. Recaro Content.
So... I am looking for a pair of Fishnet Recaro's.
A pal has a mint pair of Cortina GLS ones. I have seen them and they look slightly wider than Escort Mk2 RS2000 ones.
I intended to get them re-covered with Aldridge's excellent covers but concerned they may be different dimensions.
So, It would really help if anybody that has a set of Escort ones could measure the seat base between the bolsters front and rear.
May be handy to know for others too for the future as Escort ones in good condition are getting hard to come-by.
Re: More help from the masses needed. Recaro Content.
Hopefully this works, we didnt get the fishnets standard in the escort down under but heres some info from recaro. It may be the base on these ones youve found are different
Thanks Nursebetty but as I dont know what actual ones are fitted to Mk2 RS2000 Its a little difficult to compare.
I have measured the Cortina GLS seats and the lower base is 300mm (12") wide at the rear and 368mm (14") at the front.
Does anybody have a RS recaro they could measure for me to compare?
Yes me , got 2 fishnets in the loft
Got them out the loft what measurement are you after from where to where
