Results 1 to 3 of 3
Thread: T5 reverse gate ?
    Spanner Monkey paulmex's Avatar
    Aug 2004
    n.yorks
    357
    T5 reverse gate ?
    Hi All
    Is the gate for reverse on a Cossie T5 box inside the box or on the gear lever assembly ?
    My box has a quick shift but has no gate for reverse, I wondered if it the q shift or box at fault
    cheers paul
    3,242
    Re: T5 reverse gate ?
    That usually happens on T9 boxes when the lever is installed backwards - worth checking?
    Nov 2004
    Sweden
    1,167
    I would say it is in the gearbox, or rather in the extension housing with the ball and detent track. Check out a T5 rebuild video on YouTube and you will see. There is a good one with Eric the car guy.
    Gustaf
  5. The Following User Says Thank You to therealpinto For This Useful Post:
