Wheel bearings
I run a anglia van casing on my escort, the casing has seen better days so I was thinking of shortening a escort casing to Anglian width but the wheel bearings are different width can I fit escort wheel hearings to a anglia half shaft does anyone know if this is possible ?
Re: Wheel bearings
Yes, the bearings have slightly wider inner race with wider outer race
Re: Wheel bearings
Ordered a escort bearing will fit it to the Anglian shaft and check it all before welding it up thanks for the reply
