Pinto Electronic ignition
As tital wanted a pinto electronic ignition system , Anyone . Cash waiting
Re: Pinto Electronic ignition
Hi mate yes i have some
1 off stnd with vacume as used
1 off race: With removed vacume altered advance ..static timing 18 deg all in 38 deg (i use a 24 volt starting system for this)(looks reconditioned)
1 of fast road: Vacume removed altered advance static timing 12 deg all in 38 deg (looks reconditioned)
also have module and coil and associated wireing all in armoured and sheathed cable..
Let me no what you want.. Cheers madragon
i think i have everything apart from the distributor if you can't get a complete set-up
I would b interested in the fast road set up how much would you be after?
