Results 1 to 12 of 12
Thread: Help needed - hydraulic followers
    Jul 2008
    G67 2DU
    hi, I've just fitted a new set of followers to my cosworth but now they are quiet when cold and start to tap when hot the opposite from the old ones I took out? the engine has only been run a few times at a fast tickover will a drive help - dont want to make things worse.
    new mobile 1 15/50 oil in the engine
    any suggestions
    World Champion Decade Plus User Scouse's Avatar
    Sep 2001
    Merseyside
    1,367
    Re: Help needed - hydraulic followers
    Driving the car will certainly help as the followers need to be filled with oil for them to go quiet. (not that I have ever heard a quiet cam follower berfore, though! )
    Scouse.
    Jun 2007
    Whitley Bay
    3,437
    81
    Ive read its best to sit them in a tub of oil over night before fitting them?
    Screaming 1300 mexico rep
    Sep 2001
    Merseyside
    1,367
    Cooking oil?
    Scouse.
    Jul 2008
    G67 2DU
    Thanks for the help guys, the problem seems to be the oil and the engine temp when ticking over, as its all quiet when driving and the temp gauge is sitting slightly lower. Ive changed the temp sensor so the fans are coming on earlier but neet to find a better oil everyone I've spoken to says the mobile 1 is like water even the 15/50
    romford essex
    2,613
    86
    No its not the oil you can use mobil 15/50 or millers 10/60 all my cossys run either and all queit engines it might be down to the cheep ina followers you have , if you use genuine ones you wont get any probs hope that helps with your problem
    Jul 2008
    G67 2DU
    Hi Joe, the followers i bought from Matt Lewis Motorsport for £80 and they were advertised as genuine, the're not the cheap 40 quid ones that i've seen advertised
    romford essex
    2,613
    86
    The genuine ones are 225 quid from burtons or ford so they cant be original for eighty quid dont make sense
    romford essex
    2,613
    86
    :Give us a ring sometime in the day and il give you a few ideas how to get rid of the noise
    Clint's Avatar
    Jul 2001
    925,744
    The Original Ford Items are INA followers - the exact same part number Matt Lewis supplies so it wont be a follower issue.
    More likely to be an oil pressure issue - check the pressure when hot.
    Jan 2004
    South Africa
    3,354
    20
    Clint may be onto something.
    I had a very similar problem with my Nissan VG30. I tried thicker oil, replacing the lifters but the noise would just come back when the motor got hot. I eventually tracked it down to worn lifter guides, the oil when hot would feed up between the lifter and the guide bore so the lifter would'nt get enough oil to keep it pumped up. Replaced the lifter guide plate on the VG30 and never had problems again.
    Something you could look at.
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    My brothers just had the same issues except his wouldnt shut up, he tried another set from matt lewis and still the same, took the head off and turned out the pistons were just kissing the head as the only thing he didnt check in the build was the piston protrusion and they were 20thou over the recommendation! He was a bit annoyed as they were the forged cosworth pistons and the crank, rods and block are std so they should just fit and work!
