Results 1 to 8 of 8
Thread: Primer
    Sep 2003
    Leicester, United Kingdom, United Kingdom
    1,702
    Primer
    Hi all i need to get some primer on my car to stop it from rusting (surface rust). Now then do I put etch on it or normal primer.
    Also i will eventualy paint the car ermine so is there a special colour primer to get?
    What about the type or is etch etch? do you have to get a different type for water or 2k paint.
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: Primer
    I would use etch to protect it, but if it is to be stored for a long time it might need doing again.
    Etch is pretty much of a muchness really. Go for a well known brand if you prefer.
    Nov 2003
    Wirral UK
    7,322
    259
    Re: Primer
    All primer is porous, so if you store anything in primer it will rust.
    http://escort.accelerator.org
    Pit Crew Decade Plus User justinveal's Avatar
    Aug 2008
    south england
    35
    1,761
    134
    Re: Primer
    exactly what i was going to say but it is better than just leaving it exposed i suppose
    Pit Crew oddy's Avatar
    Dec 2008
    weston super mare
    1,238
    79
    Re: Primer
    Hi mate, as said above any primer if left is porous, easiest thing to do is get a big old tin of red lead primer from your local auto factors/paint suppliers and either roll it or brush it on, this will last the longest and is easy to sand back down again at a later date, cheers
    Sep 2003
    1,702
    Re: Primer
    cheers for the replies, i may have a go with the red oxide then
    Jan 2009
    Ireland
    201
    9
    Re: Primer
    Except of epoxy primer...
    [SIGPIC]
    Racer Decade Plus User x-pack's Avatar
    Mar 2006
    Leyland, Lancs
    2,102
    169
    Re: Primer
    can red primer be painted over ok or does it react with certain paints?
    I'm going to pull your head off because i don't like your head!
