Results 1 to 7 of 7
Thread: ST170 engine quick question
    Mar 2003
    Now over the pond North side
    3,540
    Hi All
    Quick question, is the ST170 an interference fit engine?
    If the timing belt has gone, are you in for a whole world of hurt?
    Many thanks,
    Dazzle
    Oct 2011
    Oswestry, Shropshire
    35
    792
    15
    Re: ST170 engine quick question
    Yes it is mate
    absolutely you will have a load of bent valves
    3,241
    Hi All
    Many thanks,
    Sounds like a question from a man who's just experienced a snapped belt?.........."Always with the negative waves Moriarty - for once say something righteous and positive"
    Mar 2003
    3,540
    that would be a good guess but in this instance I'm pleased to say not
    A guy is selling a SVT focus (ST170 for you guys) with some weird history of all four pots with low compression. Then he changed the timing belt, along with all the normal things you would do at the same time. Said he timed it up(?) and it was working/running great (bought it with low compression as told to him so he carried out that work)
    He then supposedly sat it for summer and when he came to run it again he thinks the timing must have come out of adjustment some how(?) So when he fired it up he thinks he bent some valves because the compression was low when he checked it?
    He says it does start occasionally if it's warm and it wants to??!!
    I'm a bit perplexed how any of this makes sense
    Dazzle
    2,659
    268
    Sounds one to steer clear of then tbh....
    low compression might be because its always been timing wrong, but i somehow doubt it. do a cylinder leakage test, that should rule bent valves in or out
