Results 1 to 8 of 8
Thread: Quaife 60G 6 speed sequential fit in a MK1 Escort
    Mar 2003
    Now over the pond North side
    3,540
    Hi All
    Just looking for advice from people who may have done this?
    I thought I had heard someone say that even though it's supposed to be a direct swap for a type 9, that wasn't the case?
    Anyone know of issues fitting in a MK1 Escort, standard tunnel on the back of a pinto?
    Any help appreciated as it may sway my imminent decision
    Dazzle
    Re: Quaife 60G 6 speed sequential fit in a MK1 Escort
    The 60g is a big gearbox and to fit a std tunnel is pushing your luck, If you are fitting a 60g to a road car be prepared to wear ear defenders. Ive got some pictures of mine but using a large tunnel if that is of any help.
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    I've fitted this box into MK2 with standart tunnel and cossie engine, and honestly it was difficult. you need to cut upside near gearstick as the box sit high. cut the original mounts also.
    you have to install something to remote fill it, as with original tunnel you can't.
    In MK2, you can keep original tunnel, but.... I'll install a wide one when I have time to be able to remove box without put the engine lower and remove xmember,...
    But it's a great gearbox, the best thing I've bought for my car.
    Mar 2003
    3,540
    Quote Originally Posted by eric View Post
    That would be great thanks Eric
    Dazzle
    Mar 2003
    3,540
    Quote Originally Posted by Mkdu View Post
    Thanks Mkdu, I appreciate you reply
    Dazzle
    Oct 2009
    417
    14
    I'd like to share what I had to face with.
    But don't know if MK2 tunnel are the same than MK1 ?
    If MK1 have smaller ones than MK2, forget it. You'll need to cut.
    I've seen, I think it's GRP4, they do a special tunnel for G60.
    Mar 2003
    3,540
    If you have any pictures, please put them up
    Always happy to listen to other peoples experiences
    Dazzle
    Bodger skandimike's Avatar
    Apr 2013
    Billingham
    115
    I have the 60g in my mk1 and like the other comments you have had you will definatley have to make mods inside the car. I have the big tunnel and had to mod that. Again earplugs a must.
