Results 1 to 4 of 4
Thread: Slipper spring bush
    May 2015
    Nairn
    Slipper spring bush
    Hi all,
    need advice, trying to fit my rear slipper springs but the gap between bushes to tight for spring to fit
    3,241
    Re: Slipper spring bush
    What, like between the rollers? Are you using a single leaf or multi leaf spring? The single leafs use marginally thicker steel so wouldn't fit rollers designed for multi leafs ?
    2,659
    268
    Or are they PTFE type bushes? I just took a grinder to mine till the front of the spring slid in an out of it nicely.
    Never had any trouble with it...
  4. The Following User Says Thank You to rallyrob For This Useful Post:
  5. #4
    May 2015
    Nairn
    Aye PTFE bushes, single leaf`s, grinder it is then
    cheers
