I have a tranx LSD to fit to my sierra 7" diff in my kit car but I also want to use the bolt on shafts and rear disc set up I have invested in rather than retain the rear drums.
I know the bolt on shaft diff stubs can be removed from a normal open diff and inserted into any other open diff to convert from bolt on to push in shafts and visa versa.
Has anyone done this with a tranx? I have heard that the stubs need modification to fit a snap ring as you cant get in to fit the normal circlip.
Any info/advice welcome
Thanks,
David
