ok oil pressure at idle 24 psi hot seems a little low to me
Now could this b the answer its a 4wd lup with a 2wd sump and i know there are differnces with the oil pumps as th 4x4 sits a little lower
SO would the pickup pipe that sits lower cause low pressure due to not enough flow?
cheers for any ideas or input you have oil is fresh 15/50 mobil and gen filter and oil feed for turbo comes from oil pressure t piece as 2wd head is blocked off
Paul
