Results 1 to 11 of 11
Thread: Balancing twin idf webers
    Oct 2018
    Midlands
    291
    Hi all after some advice on balancing twin 40 weber idf carbs on xflow prior to setting up on rolling rd.am i right in thinking to get each barrel even using synchronizer you adjust the air bypass screw? I get the lean best idle bit with idle screw procedure. Most info on net is for vw and they say to screw bypass srew right in and leave alone? Thats the confusing bit.thanks for any help guys
    4,889
    Re: Balancing twin idf webers
    Screw the airbypass screws all fully in and leave them alone.
    Oct 2018
    Midlands
    291
    Cheers.so how do i get each barrel drawing same air on synchrometer?
    4,889
    Make sure the throttle plates clear the (first) progression holes at the same time.
    If there is alot of difference in airflow between barrel on the same carb then something is not ok i.e. throttle plates might be bent. Usually this also means the mixture screws are not equally as well.
    A little difference in airflow between barrels is not a problem.
    Oct 2018
    Midlands
    291
    The barrels on each carb are same but one carbs at 5 and other at 7 plus
    you need to adjust the balence screw in the linkage
    3,239
    In an ideal world, yes a bank of dual or triple DCOE's would all open exactly in unison and air flow would be the same which in turn would draw fuel identically from each jet but the inlets of engines are rarely the same. You may get the butterflies operating equally and together but to equalise the draw on each jet through each barrel / venturi you adjust the air bleed screw - thats its only purpose in life! You can achieve absolutely identical vacuum readings ie perfectly balanced which give rock steady idle's. As Graham says difference between bodies should first be adjusted via the linkage / connection between the bodies.
    Jan 2008
    Up the garage
    2,775
    218
    Quote Originally Posted by Theyellowmex View Post
    Are they genuine Weber, or copies?
    Oct 2018
    Midlands
    291
    Quote Originally Posted by HonkyWhiteTrash View Post
    Hi there very rare genuin italian matching numbers webers.on even rarer 1970s manifold. Not cheap chiner ones.
    Oct 2018
    Midlands
    291
    Cheers. This is the confusing bit as some say leave them alone others adjust them? I spose just bit of trial and error tho they must be there for a purpose! Just need get it soe thing like to get to the rolling rd
    3,239
    Maybe advice from same people that put bike carbs on to cars, fit a 180 main jet and expect them to function correctly! All or nothing is never normally an option for anything!
