Please could some point me in the direction of where I can buy a socket for this fan switch or identify its make. I really do not like the idea of just using two spade connectors.
Two loose spades is what its designed for - has no provision for latching a connector socket...... it is what it is!
Knew it... i'll have to cover it with some heat shrink then just to tidy it up.
Exactly what i have done. From distant memory fiesta's used to have a rubber boot that slipped over the plug.
These may be of some use .... https://www.screwfix.com/p/tower-ext...ack-of-2/25996 - cut down, wires through, terminate and slip over? Heat shrink is a bit 'too permanent' possibly?
These fit, its a H7 headlight plug. Can be bought as a bare kit or made up with short tails.
