Results 1 to 10 of 10
Thread: Quick question before purchasing
    Apr 2004
    manchester
    594
    33
    Evening people
    well I’m back on the 40’s ..
    ive purchased another MATCHED pair of dcoe 31
    if you all recal from my last request I had a miss match pair.. which are going up for sale as single units ( spares etc )
    So the engine
    1640cc ( using 1300 pistons )
    cortina GT spec head ( ported & polished )
    fast rd cam ( unknown spec )
    vac-less dizzy .. side exit cap .. ( converted screw-on )
    ( the cap isn’t a perfect tight fit .. which does concern me a little )
    motorcraft type dizzy
    the carbs
    using a synchroniser I’ve balanced the carbs to each other then balanced each barrel
    twin 40 dcoe 31
    32mm chokes
    4.5 aux
    mains 130
    airs 180
    F16 tubes
    pump 40
    idle 45f9
    the car now with the replacement carbs pulls well doesn’t hesitate unlike the old ones..
    HOWEVER is a bugger on tickover .. engine surging up and down the Rev range ... revs high so I reduce the tickover ... it steady’s but then rises again
    l’ve tried altering the ( four ) idle screws but they don’t seem to have much effect
    im unsure if you screw them in to richen or weaken ?
    My thoughts are the idle jets .. but what do I go for 45f8 ???
    This is just to get it as close as I can before booking a rolling road set up ...
    and whilst I’ve mentioned that any recommendations for a good one in the north west Manchester area
    thanks Chris
    25,116
    Re: Quick question before purchasing
    screwing the idle mixture screw in leans the mixture, but only when the throttle is shut, if something is holding the throttles open slightly they will have little or no effect
    Apr 2004
    manchester
    594
    33
    Hi Graham
    I even disconnected the throttle linkage rod just to check it wasn’t holding them open
    But the linkage actually holds the throttle shut until the pedal is depressed
    There is slack in the cables
    25,116
    when you say you have balenced the throttles what are you adjusting?
    Apr 2004
    manchester
    594
    33
    With the engine warm I set the 2nd carb (screw) that connects to the 1st carb linkage .. with the balancer I adjusted this screw until both inner most trumpets had the same reading ( approximately 7 on the gauge )
    Then I then adjusted each mixture screw unit each barrel was reading the same ..
    I got the ticking over ok ... but then the revs increased as the engine got warmer ... so I reduced the main throttle screw ... engine slowed.. but after a minute or so it stalled
    I’ve checked for air leaks with a quick spray of brake cleaner with no increase of revs ...
    checked I’d NOT over tightened the carbs ( grabbing each carb body there is slight flex ) so they are not bolted up tight.
    25,116
    you dont set balance on the mixture screws! once you have set the balance on the linkage thats it, done. then once by one adjust the mixture screws to get best/fastest idle, you may then need to slow the engine down and repeat the idle mixture adjustment
  7. The Following User Says Thank You to Graham For This Useful Post:
  8. #7
    Apr 2004
    manchester
    594
    33
    I’ll give that a go thank you .. watching too many duff information YouTube videos
    So you think the idle jets should be ok then ?
    As I say I am going to get it on the rollers , just want to at least half right ...
    Next step is finding a tuning rolling road that still understands carbs
  9. #8
    25,116
    45f9 should be ok
  10. #9
    Apr 2004
    manchester
    594
    33
    45f9 should be ok
    Hi Graham ,
    I had quick look tonight whilst trying not to upset the neighbours raving it too hard
    I got it ticking over nicely using the method you said
    Get a spit / click every so often..
    I did a video but it’s too large to upload
    Get a nice clean rev ,BUT .. the engine takes a while to settle again , seems to hold the revs up .. not wildly high
    But not , tick-over speed
    Too rich ?
    Thanks for your help
    Chris
  11. #10
    25,116
    probably a bit lean, lean tends to spit and hold revs up because you need the idle mix screws a long way out to keep it idling
