Hi All,
I've finally sucumbed and decided to move away from a Cosworth lump in my Escort rally car and install a XE. I've just done a dummy run for installation ready to weld the chassis mounts and I'm a bit concerned with how far back the engine is sitting in the engine bay.
Now I know its usually good for handling to set and engine back and low, but just slightly concerned with the difference between the Cosowrth and XE.
The gearbox is mounted using the original mount used with the cosworth. The back of the engine is about 1cm away from the bulk head (which was generous in the first place). The front of the engine sits about 12 inches from the front of the chassis....miles of dead space even with the rad in.
Is this normal?
